When checking injector resistance in a 1995 you must either check the resistance between pin 45 and the injector pins or use pin 58 while the key is in the ON position. In both cases you must disconnect the battery first and for accuracy in measurement you must remove the connector from the ECU (10mm bolt). Good injector resistance should be close to 12 ohms.
(Total Mouse Over Hits: a Lot) www.mytwinturbo.com Watch an ECZA meet caravan! Download my Nissan 300ZX Vin/Model Lookup |
